Home
Products
Purchase
Downloads
Partner
Developer
About Us
Download
Buy
Upgrades
Animated Tutorials
iClone animated tutorials have been created to introduce you to the application, guide you through the creation process and provide you with a few tips along the way. Each tutorial focuses on a different portion of the authoring process and will help you towards 3D real-time filmmaking, animated storyboarding, and simulation training.
*You will be redirected to YouTube or other websites by clicking "online video" buttons,
and redirected to premium member page for download (after log-in) by clicking "download video".
Category:
Date:1/5/2008
3DXchange2 - Animate SKP Models
In this tutorial we will download an airplane model to convert to a prop in iClone Studio. New Path Helper objects will be added to animate the plane with motion clips and paths. Download helper
Date:1/5/2008
3DXchange2 - Refine SKP Models
Using Google SKETCHUPs large library of models to choose from, iClone 3DXchange now has the option to access and download any asset you can find in the Google collection. You can now manipulate extra features in 3DXchange such as Opacity and Illumination making each model even more realistic before its inception into iClone.
Date:11/9/2007
Fashion Show in 3D Gallery
In this tutorial you will learn how to create and render multiple iClone scenes for importation into MAGIX Movie Edit Pro. Once in Movie Edit Pro you will learn how to use the 3D Gallery transitions to develop rich 3D movement in-between your iClone clips.
Date:11/9/2007
3D Animation with Realistic Scene
In this tutorial you will learn how to create a chromo key effect on a rendered avi output from iClone 2.5 and place it in MAGIX Movie Edit Pro over live footage.
Date:10/31/2007
Quick Guide to Video Editing
In this tutorial you will learn how to use iClone and Movie Edit Pro to provide a quick and easy platform for Video Editing.
Date:10/31/2007
Overlaid Avatar - Chromo Keying Method
In this tutorial you will learn how to create a chromo key effect on a rendered avi output from iClone 2.5. This is a scenario that is easy to set up in iClone using a single avatar and a solid green 2D Background.
Date:10/30/2007
3DXchange Jeep Tutorial
This tutorial introduces how to export certain nodes of a model to transform a non-animated 4 wheel vehicle into an animated vehicle with spinning wheels.
Date:10/20/2007
3DXchange Basic Operation
3DXchange is a powerful converter that makes it easy for users to convert any 3DS or OBJ file. Using content created in applications such as 3DStudio Max, ZBrush, SketchUp, Maya, etc…users can convert and edit their models for import into iClone as props, accessories or even 3D scenes.
Date:10/9/2007
iClone 2.5 - Character "link to" Horse
In this tutorial you will learn how to animate a horse live prop using preset motion animation clips, how to link a rider to your horse and how to link a horse to a character so that the horse prop will retain the character animation in conjunction with the live prop motion clip.
Date:9/10/2007
iClone 2.5 - Character "link to" Prop
In iClone 2.5 characters can be linked to props via the Link To feature. Most assets inside of iClone 2.5 carry this new ability, allowing users to attach or link characters to other assets.
Date:9/10/2007
iClone 2.5 - Character "link to" Character
In iClone 2.5 characters can be linked to other characters to create interesting animation via the “Link To” feature. Most assets inside of iClone 2.5 carry this new ability, allowing users to attach or link two characters together or characters to props.
Date:9/5/2007
iClone 2.5 - Prop "link to" Prop
In this tutorial you will learn how to link a prop to other props using the Link To feature and the Link To Sub-Node menu. This introduces the “Parent – Child” relationship between iClone assets.
Date:8/24/2007
Avatar Joint Constraints
This tutorial will make users aware of avatar joint constraints and how best to correct them when they are exceeded. These limits can be observed by a “twist” in the mesh, or a “break” in the CloneCloth mesh layer.
Date:8/21/2007
Skin Texture - Tattoo & Make-up
This tutorial focuses on editing this skin diffuse layer in order to create virtual tattoos and make-up for both the heads and upper bodies of iClone avatars. Using digital images of both traditional and tribal tattoo designs, you will create sleeves and chest pieces along with custom facial textures.
Date:8/4/2007
DAZ to 3DXchange to iClone Tutorial
The iClone real-time production environment can be used along with other modeling tools like DAZ Studio to populate props, scenes and accessory libraries. DAZ is a free download and provides the tools to create people, animals, vehicles, buildings, props, and accessories plus much more.
Date:7/16/2007
Creating multiple skirt lengths and styles for CloneCloth Avatar
This being the rule allows users to create many different styles, cuts, lengths and so on. You can design as many different opacity styles as you like, giving you as many custom character outfits to apply to your avatar, even only when using a single G2 CloneCloth character.
Date:7/3/2007
iClone Lighting Features and Techniques
In this tutorial the focus is on the default lights, their attributes and how to access them. Custom Light animation and how to set key frames to create and save your own animated lights. And finally, how to simulate a cone light using a 3dBlock prop along with opacity and glow maps.
Date:6/28/2007
Assemble your G2 character with skin texture
This tip is aimed to teach you how to assemble your G2 characters with skin texture after purchasing a G2 Texture pack. Generally, you might get upper, lower, shoes or skin textures within the content pack. But the skin texture is little different as conducting upper/lower textures for your character.
Date:6/20/2007
iClone 3DXchange Overview
This overview tutorial will introduce users to the key features, user interface, tools, panels and options presented when using 3DXchange. Introduction to creating custom props and custom accessories is also covered in 20 easy to follow steps.
Date:6/10/2007
How to convert 3d objects from Hexagon2
Hexagon 2 is a 3D Polygonal modeler for three-dimensional computer arts, delivering accessible yet advanced 3D modeling tools for illustrators, graphic artists and expert modelers and animators. This tutorial is aimed to introduce the procedure when you are going to apply this tool for iClone.
Date:5/21/2007
Making a Suit of Indian Clothes
First of all I assume you have a basic understanding of how to export the diffuse and opacity graphics into your Graphic Editor. You will also need to be fairly conversant with your Graphics Software. In this tutorial, you will learn how to make a suit of Indian clothes.
Date:5/18/2007
iClone 2.0 Timeline overview
The TIMELINE opens the door to the animation power of iClone’s 6 basic elements and more, including LIVE props for your scene that install with custom preset motion animation clips, and learning how particle effects can be attached to props and/or accessories to gain total control of environmental and atmospheric effects.
Date:5/14/2007
Using 3DXchange to Make a Quick Room
This is an example of a flat surface with single-sided normal. We can use 3dXchange, a simple 3D Box primitive from iClone and your favorite image editor to make a very quick room prop that behaves much like the stock 3D scene. This type of scene or prop makes camera angles easier to adjust and because the normal are flipped, lighting passes through the wall unobstructed.
Date:5/5/2007
The demonstration of 3DXchange for iClone conducting reflection
First, be sure to make an apple generated from 3ds Max is to 3DXchange with texture. Second, apply "reflection" & "bump" to change the performance of your objects. Finally, with slight modification in iClone, you will see the amazing outcomes iClone could achieve.
Date:5/1/2007
Apply the Flag as Your Accessory using Daz Studio
This tutorial is aimed to show you how to edit your flag in Daz3D for iClone through 3DXchange. To connect the relationship between the character and the flag, we need to apply the flag as the category of "Accessory" in iClone. Finally, you need learn to adjust your images to fit the flag. Let's see what it was done.
Date:3/15/2007
Creating & Cutting CloneCloth
CloneCloth is an exciting new gateway into virtual fashion design. Using an image editor, such as PhotoShop, Painter, Paint Shop Pro, etc, along with iClone 2.0, you can be a fashion designer and a 3D animator all at the same time.
Date:3/15/2007
Linking particles to characters and dummy objects
This is a powerful feature that can be used to quickly create awesome character and particle motion interaction. Using the particle modifier interface you can edit the default particle settings and link the emitter to your character and dummy object.
Date:3/15/2007
Creating custom particle helper - Comet
Using Particles in your scene greatly enhances the suspension of disbelief. In this tutorial, you will learn how to apply a prop with a specific path to simulate the movement of a comet. In addition, the particle of burning fire will be attached to the prop to rock the galaxy.
Date:2/25/2007
SFX Case Study (1) - Aurora
A lady is posing in front of a relic while the aurora generates in the sky. The elements in this scene are an avatar, a relic prop and an emitter that sends the aurora.
Date:2/25/2007
SFX Case Study (2) - Lightning
A lady is nagging at the other one. The latter one casts the lighting to stop the insult. The elements in this scene are two characters, a church 3D scene, and an emitter that gives lightning.
Date:2/25/2007
SFX Case Study (3) - Cast Spell
A girl in the garden cast bubbles by means of a magic circle in the right hand. The elements in this scene are an avatar, a 3D LivePlant scene, a motion accessory, and an emitter sending blue bubbles.
Date:2/25/2007
SFX Case Study (4) - Rain
A girl runs in the pouring rain as the rain starts abruptly. The elements in this scene are an avatar with motion, a 3D scene, several emitters that emit rain, spray on the ground, and the ripples.
Date:2/25/2007
SFX Case Study (5) - Fountain statue
A statue spraying water locates in a fountain in the middle of a square. The elements in this scene are a statue disguised from an avatar, a custom fountain prop, a house and a wall, SFX-fog and an emitter that emits water.
Date:2/15/2007
Custom Environment Particle Settings
In this tutorial we will apply a TORCH FIRE default particle to a default 3D block (Ball_001) and then edit its settings to create a very realistic Comet complete with a flaming, dissipating trail. When a prop is combined with a particle system and then saved, it becomes a PARTCLE PROP.
Date:1/18/2007
Machinima 101 Film Terms
A tutorial that teaches you various film terms. Terms including: 180 degree rule, pan shot, over the shoulder shot, medium close up shot, low-angle shot, dutch tilt, bookends, blocking and etc...
