Home
Products
Purchase
Downloads
Partner
About Us
Download
Buy
Upgrades
Persona Generator is the service for iClone user to experience the power of customized AML Script.
This generator contains three sections: Move, Perform and Idle. After you have selected the radio buttons for the motions you want, you can export the AML script and import it right into iClone.
Please pay attention to the notes below each section of the command.
Move
Walk Speed(cm/s)
Rotate Speed(degree/s)
Lock
135
120
130
120
160
120
110
120
Run Speed(cm/s)
Lock
250
120
300
120
200
120
Note:
  1. Select the motion (Walk/Run) you would like to use in the "Move" section.
  2. In the "Move" section, "Lock" excludes "Perform" and "Operate" commands from interrupting.
Perform
Clip Duration(Sec)
Hotkey
Custom
Lock
Sample Transform
2.76
5.09
4.17
3
5.01
4
5.44
5
  1. Select the motion you would like to use in the "Perform" section.
  2. Hotkey, the hotkey you use when you are in Director mode.
  3. Custom”  More...
Idle
Clip Duration(Sec)
Occurrence
Custom
2.82
2.67
5.00
7.50
2.32
Note:
  1. Select the motion you would like to use in the "Idle" section.
  2. Occurrence” , sets the rate of appearance to the selected motion.
  3. Custom” More...
After "Export", follow the steps below to import your AML Script into iClone.
  1. Launch iClone.
  2. Drag an Avatar into the scene.
  3. Right-click on the avatar to import Persona.
Note:
If you want to see the idle motion in editor mode please go to avatar > persona > modify panel and check the "Auto Add Idle Motion" in iClone.
Recommended 3rd Party AML Application
AML Optimizer Pro  AML Writer
