| Filming & Directing Movies |
Actor Creation Actor Customization Scenes & Sets Filming Materials & SFX Rendering & Output Developer Tools & Plug-ins |
Directing with the Timeline key frame animation controls |
Set and Animate Cameras, Lights, Characters, Props, accessories and more with simple non-linear editing.
Expanded prop animation with clip library, easy to create and connect motion sequences for special Live Props.
Build animated lighting with color, brightness and shadow dynamics.
Animation tracks in a floating and scaleable GUI.
Cut, Copy & Paste key frames or key frame groups.
Scrub the timeline for intricate real-time preview.
Collapsible tracks for targeted editing.
Zoom for full project view or magnified view.
Auto-Key animation with toggle on/off.
Frame jump numerical play head control.
Hotkey system for quick editing.
Tween animation.
Motion Editor - Motion animation, mocap blending, and pose creation tool for actors |
Added data input to edit joint rotation.
Added lock-motion-to-pivot function, enables free control of character movement in the iClone timeline.
Added align-whole-motion function to remove foot sliding problem caused by Mocap data.
New functions for BVH bone-structure remapping and VNS motion exp.
Motion Editor, create, edit & blend poses and body motion animation using our character dummy to select and adjust the character joints. The timeline editor enables keyframe animation for assigning custom motion creation or blending based on time and ease.
Create new motion using the tween animation creation allowing
you to pose the dummy and assign a key frame to the timeline,
then moving down the timeline and changing the pose with
a new key frame. The tween animation automatically animates
your character from pose-to-pose instantly.
Add multiple preset motions to the timeline for blending, cutting, and easing to create a combination animation.
Create static poses for your characters.
Rotoscope - Import a video background into Motion Editor to use as a reference to sync your poses and motions in order to replicate the motion performed by the video character.
Quick and easy pose editing - simple hotkey and mouse wheel speed editing. (click to select joint, right click to switch axis, rotate wheel to rotate join)
Change motion speed, enhance or fix original motion capture data, loop motion, add velocity, change part of the joints angle in the mocap sequence.
Rich motion assets available for reuse and edit - download standard BVH files and load into Motion Editor - see download reference sites.
* See Motion Edior Visual Reference
Camera Controls and Animation |
Hand Gestures |
Multiple Character selection and management tool |
Area rendering preview selection tool |
Real-time preview markers and looping |
Direct Picking and Manipulating Selected Objects
Add Linkage between Objects and Characters
