Preview Camera
Follow Cameras
Custom Cameras
Purpose
To provide basic operations in Editor Mode.
To observe scene and objects from different angle.
To easily transform and move objects.
Not adding camera keys to timeline
To simulate Game Camera in the
Director Mode, always keep your target in the center of the
screen.
Use F7 to toggle Action Game mode (view from back) or
Strategy Game mode (view from top right).
To follow the selected actor or iProp when you control them via
WASD hotkeys.
To provide availability to custom offset for the cam angle.
To set camera keys for playback.
To finely adjust in the Timeline.
To be switched among cameras in Timeline.
To be able to Link/Unlink
or Look At/Set Free in different point of time.
Key Generating
Not Available
You may access the Preview Camera and modify it's parameter,
but no key is set.
Use Preview Camera for data preparation, object transform
editing, tasks not involving in changing the final
camera keys, or just for previewing the project.
Editor Mode: A key in a particular frame can be changed or
added as soon as the camera view is changed.
Director Mode: A key in a particular frame can be changed
or added as soon as the camera view is changed. But it pauses the
recording process.
Being Toggled by Camera Switcher to Shoot
Not Available, because the Follow Cam
only appears when an
actor or an iProp is picked.
You must link and adjust a custom camera to the target object to film if the
result from the Follow Cam is
preferred.
Camera Selection
It is the default camera when you enter the Director Mode.
You may select the Follow Cam from the
Camera Selector in the 3D viewer.
Alternatively, press F7 to quickly switch between
Follow Cam - Actor and Follow Cam - Bird.
The Follow Cam are eliminated as no actor or iProp is picked.
Walk/Fly Navigation (Press + or - to modify the navigation speed.
The speed can be saved in project)
Available
added as soon as the camera view is changed by the
navigation.
If you navigate the whole scene while recording
(Director Mode), the navigation course can be automatically
filmed as a clip.
In the Editor Mode, Walk/Fly
Navigation is a method to set the camera view. Only
one camera transform key is added instead of recording the navigation
course.
Look At
Always keeps the relative position and angle to the
actor/iProp.
You may adjust the relative camera position and angle if necessary, but no key added.
