Selecting Data in Timeline (New for 5)
Key/Clip Selections
Select single key/clip - Single-click on the target
key/clip, the selected key/clip will be highlighted in blue.
Tab Key - Press Tab to jump to the next key/clip, then
Shift + Tab to jump to the previous key/clip.
Select All keys/clips - Double-click on the target track name.
Multiple keys/clips selection
Drag the cursor in specific track to highlight the keys/clips covered under.
Use Ctrl + LBM (Left Mouse Button) to select multiple keys/clips.
Use Shift + LBM to select the adjacent keys/clips.
Copy Keys or Clips - Use Ctrl + drag keys, or clips, to duplicate them.
Span-tracks Data Selection
In iClone, you are allowed to select data stored in different tracks. It is convenient to
edit data at one time instead of editing separately in different tracks.
Use Ctrl + LBM to select multiple keys/clips in different tracks.
Use Ctrl + double-click on a sub track name to select all the data in different tracks.
Note:
You may span-track select data from the tracks that are under the same main track. The data from the sub tracks that belong to different object may not be selected at the same time.
Please refer to the Timeline Shortcuts section for more information.
