Drag-and-Drop to Preview Window
Instead of using the Content Manager or Import methods to load your assets, you can drag and drop them into the iClone Preview Window from your system explorer.
This way you can store all your desired files in a single folder and use the Drag-and-Drop feature to quickly load them into iClone.
If you are using a dual-monitor environment, you can have multiple explorers displaying your assets on one monitor and then drag the assets into iClone running on the other monitor to increase your production efficiency.
Drag and Drop
Drag and Drop Media to Space
If you drag and drop an image or video onto the space of the project, it will be set as 2D background.
Drag and Drop Media to Object
Drag and drop an image or video onto an object and it will be mapped to the Diffuse channel of the object.
Drag and Drop With Ctrl Pressed
Drag and Drop from Content Manager to Folder
Not only can you drag and drop assets into iClone but also the other way round. Assets can be dragged from the iClone Content Manager to any target folder for better management.
Drag and Drop Media with Right Mouse Button
When you drag and drop a media files with right mouse button, you are prompted with a menu to select the desired action for how the media is applied.
Drag and Drop Mesh Objects
You can drag any object with meshes such as Actors, Props, Accessories, Terrain, Sky... etc. into iClone to load it at the location you drop it.
Variations of Accessories
If you drag and drop an accessory file (.iAcc) on an actor, it will follow the accessory's conventional behavior; if dropped on the floor, it will become a prop.
Drag and Drop on the Actor
Drag and Drop on the Floor
(become a prop)
Drag and Drop Non-Mesh Objects and Media
Non-mesh objects (Particles, Grass, Material...) and Media (Images, Videos, Audios...) can also be applied into iClone by using the drag-and-drop method.
Material
Drag and drop a material file (.iMtl) to any dragable object (with mesh, trees excluded)and the images in the seven channels will be replaced with the ones saved in the material file.
Before Drag and Drop .iMtl file onto the prop
Drag and Drop .iMtl file to the target face
Result
Image and Video
By dragging an image or video and dropping on any dragable object (with mesh, trees excluded) or sky, you can replace their original image in the Diffuse channel.
Drag and Drop Image or Video
Result
Audio
When you drag and drop an audio file (.wav, .mp3) into the preview window, the file will be imported and set as the background music of the project.
Supported Asset Files
In general, any asset file with an extension that starts with "i" can be dragged and dropped into the preview window.
Navigation Pane Tabs
Sub Tool
Ext. File Name
Sub Tool
Ext. File Name
Sub Tool
Ext. File Name
Project
Open Project
.iProject
Stage
Image Layer
.iImageLayer
3D Scene
.iScene
Atmosphere
.iAtm
Fog
.iFog
Camera
.iCam
Light
.iLight
Effect
.iEffect
Set
Props
.iProp
Tree
.iTree
Grass
.iGrass
Particle
.iParticle
Terrain
.iTerrain
Sky
.iSky
Music
.wav, .mp3
Actor
Avatar
.iAvatar
Hair
.iHair
Upper Body
.iUpper
Lower Body
.iLower
Gloves
.iGlove
Shoes
.iShoe
Accessories
.iAcc
Skin
.iSkin
Head
Faces
.iFace
Eyes
.iEye
Mouth
.iOral
Animation
Motion
.iMotion
Hands
.iHand
Path
.iPath
* Please note that asset files from before version 3 (.VNS files) can only be imported using the drag and drop method by switching to their correspondent tabs first - i.e. Set > Props for props, Actor > Avatar for characters, etc.
