Spotlight - Look At
When you want to shine a spot light on a target object, you may use the Look At feature.
  1. Select an unused directional light in the Scene Manager.
  2. Go to the Stage/Light/Modify page, in the Light Setting section, select Spotlight.
  3. In the Look At section, click the Pick Target button.
  4. In the 3D viewer, click on a target.
  5. Move the target object away to see the result.
The spotlight rotates and follows the moving actor
Note:
  • You may also have the spotlight Look At the target object over a certain period of time and have it be Set Free outside the time range.
