The Comparison of Linking and Attaching
This chapter provides the comparison table for Linking and Attaching.
Linking
Attaching
When to Use
  • Passing an object from one parent node to another in a specific time.
  • Changing the camera's view to another actor's or object's view.
  • Having the light to move with another moving object.
  • Creating a merged object and add it into the Custom library of Props.
  • Adding an actor with accessories into the Custom library of Actor.
  • Converting a model with an iProp Helper to become a custom iProp. Please refer to Creating Animation Helper and Prop Animation with Helper sections for more information about Helper.
Same Behaviors
  • The child node follows the parent's transform data - R/T (no option)
  • The child can still be transformed after linking.
  • Picking the bone nodes directly is available.
  • The child node follows the parent's transform data - R/T/S (optional)
  • The child can still be transformed after attaching.
Picking Parent/Child
  • Single click to pick the parent, as well as the child.
  • When the parent is not selected, right click on the child node will turn on it's right-click menu.
  • Single click on the parent or the child to pick the grouped object.
  • Double click to pick the child.
Generating Keys in Timeline
  • Available.
  • Not Available.
Saving Relations in Project
  • Available.
  • Available.
Multiple Objects
  • Supported
  • Supported
Saving Parent to Library
  • Parent-child relation is broken.
  • Only parent is saved.
  • Parent-child relation is saved.
Auto Align Position to Parent
  • Not Available.
  • Align Position to Parent box in the Link to Sub-Node dialog must be checked manually.
  • Not Available.
  • Align Position to Parent box in the Attach to Sub-Node dialog must be checked manually.
Prop to Actor
  • The prop remains a prop.
  • The prop converts to an accessory.
Levels
  • Multiple levels available.
  • Recursive linking is forbidden.
  • One level only.
  • Merging parent and child as one new object allows to attach more children.
  • The merged child becomes a permanent component of the parent and is no longer able to be detached nor transformed.
Hierarchy in Scene Manager
  • No change.
  • Changes.
  • Child is moved under the parent node.
iProp Behavior
  • Double click to pick the child and use the Right-click Menu.
