You may follow the steps below to re-record if you are not satisfied with the result of the last Director Mode recording.
Click the right mouse button on your actor or prop.
In the Right-click Menu select the Remove All Animation option.
The recorded keys and clips in all tracks belonging to this object will be removed. You may then go to the Director Mode to record again.
Note: |
If you stay in the Director Mode and you want to remove all the previously recorded clips and record again, please follow the steps below.
Click on the Reset
button on the Quick Tab Bar.
Click OK to reset and remove all recorded data for this session.
The data in all tracks are reset to their initial status the moment you switched to the Director Mode. You may then start to record again.
Note: |
