The Comparison of Cameras
The multiple camera system in iClone contains Preview Camera, Follow Camera and Custom Camera.
Preview Camera
Follow Cameras
Custom Cameras
Purpose
  • To provide basic operations in Editor Mode.
  • To observe scene and objects from different angle.
  • To easily transform and move objects.
  • Not adding camera keys to timeline
  • To simulate Game Camera in the Director Mode, always keep your target in the center of the screen.
  • Use F7 to toggle Action Game mode (view from back) or Strategy Game mode (view from top right).
  • To follow the selected actor or iProp when you control them via WASD hotkeys.
  • To provide availability to custom offset for the cam angle.
  • To set camera keys for playback.
  • To finely adjust in the Timeline.
  • To be switched among cameras in Timeline.
  • To be able to Link/Unlink or Look At/Set Free in different point of time.
Key Generating
  • Not Available
  • You may access the Preview Camera and modify it's parameter, but no key is set.
  • Use Preview Camera for data preparation, object transform editing, tasks not involving in changing the final camera keys, or just for previewing the project.
  • Not Available
  • You may access the Follow Cam and modify it's parameter, but no key is set.
  • Editor Mode: A key in a particular frame can be changed or added as soon as the camera view is changed.
  • Director Mode: A key in a particular frame can be changed or added as soon as the camera view is changed. But it pauses the recording process.
Being Toggled by Camera Switcher to Shoot
  • Available
  • Not Available because the Follow Cam only appears when an actor or an iProp is picked.
  • You must link and adjust a custom camera to the target object to film if the result from the Follow Cam is preferred.
  • Available.
Camera Selection
  • You may select the Preview camera from the Camera and Shader Selector in the 3D viewer.
  • It is the default camera when you enter the Director Mode.
  • You may select the Follow Cam from the Camera Selector in the 3D viewer.
  • Alternatively, press F7 to quickly switch between Follow Cam - Actor and Follow Cam - Bird.
  • The Follow Cam are eliminated as no actor or iProp is picked.
  • You may select the Custom camera from the Camera Selector in the 3D viewer.
Walk/Fly Navigation (Press + or - to modify the navigation speed. The speed can be saved in project)
  • Available
  • The navigation course can not be filmed.
  • Available
  • Available
  • A key in a particular frame can be changed or added as soon as the camera view is changed by the navigation.
  • If you navigate the whole scene while  recording (Director Mode), the navigation course can be automatically filmed as a clip.
  • In the Editor Mode, Walk/Fly Navigation is a method to set the camera view. Only one camera transform key is added instead of recording the navigation course.
Look At
  • Not Available
  • Always keeps the relative position and angle to the actor/iProp.
  • You may adjust the relative camera position and angle if necessary, but no key added.
  • Available
  • You must enable/disable the Look At feature manually, and it is added as Look At key in the Timeline.
