Operate Track
The Operate track is a very unique track since it works only when an interaction between an Actor and an iProp occurs. After the interaction is finished, iClone stores the motion from the actor and the animation from the iProp into their individual Operate tracks.
Director Mode
In the Director Mode, you may command your actors and iProps to Interact via the Right-click Menu or Hotkeys during the recording process. Once the interacting process is done the motion and animation from both the actor and the iProp will be stored right onto their Operate tracks.
  1. Toggle the Director Mode by click the button if you are in the other mode.
  2. Make sure that you have selected the desired actor to interact first.
  1. You may have your actor interact with the iProp through two methods as it is recording:
  2. The motion and animation clips will be stored into the Operate tracks individually as the interaction finishes. These two tracks store the motion of the actor and the animation of the iProp. (The play bar displays the actor-related tracks only.)
Editor Mode
In the Editor Mode, you may also add motion/animation clips into the Operate tracks. However, you can only achieve this goal by using the Right-click Menu.
  1. In the Editor Mode, click on the actor for interacting.
  1. Right-click on the desired iProp.
  2. Select any sub-command in the Operate entry.
  1. The motion and animation clips will be stored into the Operate tracks individually. (The play bar displays the actor-related tracks only.)
