You can create your own unique puppet profile or modify existing profiles from the Edit Property pane.
Click the Clear Selection
button to deselect all features.
Pick the desired features in the Solo Feature Selection pane.
Click the Preview
button, press the
Space bar, and move your input device (mouse by default) to preview the movements of the selected features.
If you are satisfied with the result, click the Save Profile
button to save
your custom profile.
Click the Open Profile
button to load an existing profile.
To customize your own puppet control profile, you may want to adjust the weight of each feature manually.
Click the Edit Property
button to expand the weight pane.
Modify the values in the Weight column of the corresponding feature to specify the weight of the movements triggered by the movement of your input device.
Click the Preview
button, press the
Do steps 3 and 4 repeatedly until you obtain satisfying results.
Click the Save Profile
button to save
