iClone provides you with multiple channels to modify the texture individually. The channels are Diffuse/Opacity/Bump/Specular/Glow and Reflection. With the Paint Tools provided, you may draw on the pane directly or edit the channel in your Image Editing Software.
Diffuse:
Select Diffuse in the Map Channel drop-down list.
Change the brush color and adjust the brush size/opacity.
Paint directly on the plan window.
The 3D view port will change instantly to reflect the changes.
![]() Diffuse Channel Modified |
![]() Result |
Opacity:
Select Opacity in the drop-down list.
Repeat the steps you did for the Diffuse texture to modify the image.
![]() Opacity Channel Modified |
![]() Result |
Bump:
You may add a grayscale image or a Normal Map to create bump or wrinkle effect
on the face.
Select Bump in the drop-down list.
![]() Bump Channel Modified |
![]() Result |
Glow:
Select Glow in the drop-down list.
![]() Glow Channel Modified |
![]() Result |
Reflection:
Select Reflection in the drop-down list.
![]() Reflection Channel Modified |
![]() Result |
