iClone simulates the effects of gravity on the female body with spring effects. Please refer to the Spring Props section for description on parameter tuning.
Click the thumbnails below to view demo video.
For G2 and G3 female actors without prior setting of bouncing effect, you may turn on this effect through the following process.
After the target character is assigned with the spring settings. You may turn on the
Spring Effect and modify parameters to create your custom effects.
Note: |
To enable the real-time rendering of spring effect, please turn on the Flex/Spring FPS Sync option in the Preference panel. Turning on Flex/Spring FPS Sync option may increase graphics process loading, you may check it off to keep the optimal rendering speed. The Flex/Spring FPS Sync setting only applies to the 3D viewer. If you export a project with spring props, iClone always renders with Flex/Spring FPS Sync setting enabled even if the setting is disabled in the Preference panel. |
