iClone presents you with a brand new type of prop, iProps. Each iProp contains built-in animation clips that enable you to Perform Actions, Move Around or even allow your actor to Operate it.
Operating an iProp allows your target actor to interact directly with the iProp. We will take an iProp jeep, as an example to describe the way you use the iProp in your scenes.
If you want your actor to interact with the iProp using its default action, please follow the steps below:
Select the actor you want to use first.
Press and hold the Ctrl key and click on the target iProp.
The actor will then walk towards the iProp and start to interact with the iProp using the default animation.
If you want the actor to interact with the iProp using a different action, please follow the steps below. In this example, the jeep is the target iProp and the man is the actor.
Drag and drop the jeep from the library.
Select the actor that you intend to interact with the jeep.
Click the right mouse button on the jeep to pop up the right-click menu. Move your mouse over the Operate entry.
Select the desired Operate function from the sub-menu.
The actor then automatically interacts with the jeep, performing your chosen action.
The actor walks to the jeep and opens the door. |
The actor gets in the jeep. |
Please refer to http://www.iclonewiki.com for more information about creating and modifying Persona and DramaScript.
