You can find this track grouped in the sub-track set of Actor, Props, Camera, and Light. In the Transform Track, you may set keys in different frames; iClone will generate the transition animations automatically. Each key in the track stores the Move, Rotate, and Scale data of the target object in the current frame.
Start Frame: 0 |
End Frame: 300 |
Start play back and the box will move automatically |
Start Frame: 0 |
End Frame: 300 |
Start play back and the box will rotate automatically |
Start Frame: 0 |
End Frame: 300 |
Start play back and the box will scale automatically |
