iClone provides several categories of particles for you. They are:
Environment - The templates simulate the environmental phenomena such as fog, cloud and so on.
Fire and Smoke - Many kinds of fires can be applied to your projects.
Miscellaneous - Some other templates for further use.
Text - You can have your own logos, texts with special effects to amaze your audience.
Tunnel - You will find many tunnel effects in this category, such as time tunnels, wormholes, etc.
Water - Springs, waterfalls, any type of water you want can be found in this category.
Please click the Set tab in the navigation pane.
Press down the Particle button.
Switch to the template tab. Simply double click on any one template in these categories and your project generates particles accordingly.
Play back the project to see the result.
As for the other parameters for adjustment, please read the next section:
