iClone provide auto-add-idle-motion feature for each actor you apply into the project. Actors then generate automatically the vibrating or breathing motions as playing or recording. However, the feature is turned off by default.
If you want iClone to automatically add idle motion in the Director Mode or the Editor Mode, you may turn on this feature.
Select an actor.
Go to Actor/Persona.
In the Modify Page, check the Auto Add Idle Motion box.
Start playback in the Editor Mode, the actor will present idling motion.
Note: |
