The Time Setting panel enables you to adjust the Length and Time Unit of the project. Click the clock button next to the current time counter below the 3D view port window to open the Time Setting Panel.
This button opens the Time Setting dialog box for further adjustment.
Animation Length: Shows the total length of the project in frame count. The default length for each project is 2000 frames and the maximum number is 18000.
Select Time Unit: You may decide to display the time unit in either frame or time format.
Tip: |
