3.0 New Features
Reallusion has reinvented iClone with an ideology: CREATE - PLAY - EDIT - SHARE.
iClone combines the interactive productivity and play experience of a videogame-based Machinima
tool with the power of a professional multiple timeline 3D animation
program, that is easy to use and packed with features.
Two Production Modes
Editor Mode and Director Mode.
Reallusion saves the time and cost to have a dual-engine
3D power PC.
Use Editor Mode to create your scene and
place your actors.
Use Director Mode to command how your Actors and
iProps move just like playing a videogame.
Then use Editor Mode again for fine-tuning,
editing and exporting
your footage.
Right-click Menu System
Each type of object has its own actions and tools, just right-click to bring up the
objects associated menu with options for editing and interactivity.
The Right-Click Menu system saves you from having to search everywhere around the user
interfaces for the right tool.
DramaScript
It is an Action Script that allows you to define custom interactivity,
use hot keys and the right-click menu to control the
actors movement on the terrain, to sit on the chair, to drive the car or
even ignite an explosion, etc. Almost anything is
possible with DramaScripts.
You are able to create your own unique movement, set the actor's
personality and invent your own interactive Props (iProps).
Tab Track Editing for Standard users
You may record what you play and re-record what you don't like.
You will find the yellow highlighted action segments when you tab or reverse tab
on the play bar.
The segments in the play bar corresponds to the active selected object or actor.
Tab Track Editing helps you to easily jump to a motion editing point,
delete old motions or record new ones.
Multi-Actor Timeline Editing for Pro Users
You don't need the Ctrl + F7 any longer. Simply Drag and
Drop your actors into
the scene, and each has it's own set of timeline tracks for
total control.
Now, everyone can talk to each other simultaneously. You
can have a group of actors all talking or singing with
their own voices all at the same time.
Multi-Camera System
You may now add many cameras to the scene and switch to them as
often as you like.
iClone provides Depth of Field (DOF), Lens MM
features
and you are able to set keys to animate all these to create
mesmerizing effects.
Enhanced Lighting System
Point-light, Spotlight and Directional lights are all available in
iClone.
Now you can setup spectacular lighting effects with
ease.
You may attach the light to a stick to make a flash light
or torch, use Spotlights
that can follow your actors around and use the Point light to add
incredible atmosphere and enrich the
mood. Creating that eerie horror scene will now be a
breeze.
Direct 3D Object Manipulation
Inside the 3D viewer, you may make multiple object selections and
directly click and drag to move, rotate, scale, copy, and delete.
You no longer need to touch the Modify panel to position
your objects. Just think how much more productive you
can be with this feature.
Attach and Link
You may attach or link any selected object to a parent and no more flattened merged props.
You can detach your objects and reuse them again after you add them to the library.
You can link and unlink the object relationship in the animation
any time you want, no need to hide the ball in your hand if you wish to throw it away.
Motion Editing
The external Motion Editor is eliminated from iClone.
An all In-Scene Motion Building System
is introduced to replace the external editor.
You may utilize the FK (Forward Kinematics) and IK
(Inverse Kinematics) to directly pick the target segment of
the body
and pose your actors with ease.
All the motion editing features of the previous Motion Editor are replaced by the
new advanced in-scene motion builder.
The new Motion Layer function
allows you to easily modify motions in a layer-concept
similar to what you use in photo editing.
Material Editing
CrazyTalk5 CTS import
Water
iClone provides beautiful water effects with refraction, reflection,
custom speed, clarity, color and underwater fog.
Grow Your Own LivePlants, Grass and Trees
You now have a virtual green thumb and can grow your own plants in iClone
with just a few mouse clicks.
Thousands of trees will come in stages after iClone 3
is released.
Experience the iClone 3 virtual landscaping with
a variety of
included vegetation content.
G3 Character
Meet Trey and Trinity, the incredible new iClone 3 G3 actor body styles.
G3 characters are with lower polygon than G2 avatars,
with better performance, amazing look and higher
quality..
Scene Manager
All your assets in your 3D project are listed in the
Scene Manager.
There is no need to scroll the scene to search for an
elusive target item.
Select the item from the list and press the F key to instantly pop to
that object view in your 3D window.
You can also use Scene Manager to rename the object.
Use the Scene Manager to hide items so you don't waste your precious 3D rendering power
in complex scenes.
Shader Options
Any object can have its own shader type such as
Pixel Shader (the best), Quick Shader (by default), Wireframe,
Bounding Mesh, or even Hidden.
Content Creation Pipeline
You may use plug-ins for 3DS Max Character Studio to generate
your own character motions.
Use Zbrush to generate normal maps, and with the iClone 3 actor templates,
you can create actors with wrinkles or better body definition and muscle tone.
Collaboration with 3DXchange will meet all your content
needs straight from the internet.
