Visible Clip
When a visible clip is
selected, the clip type and the selected visible clip name will be shown on the
top left of the "Attribute" section.
When you have selected one
of the visible clips, the available attributes for the selected visible
clip shows below. Adjust each of the settings to set the parameter of
selected visible clip.
Target Type: This sets the type for who will be able to
trigger the parent type (iProp).
Character |
The target character
will be affected by this animation clip. |
Object |
The target object
with embedded animation clip. This prop will then be
defined as interactive prop, iProp. |
Rider |
The character who is
riding on the motorcycle or driving the car will be
affected with this motion. |
Owner |
The character who
has linked to an iProp. |
Target Node: This "$" defines the object itself. If
there is a child attached to the parent, it will be defined as
sign followed by ".child". So it will look like this "$.child".
Visible: This
is the attribute for you to set visible or invisible of the
character or the prop .
