Create New Commands:
Perform Commands
- From the command
drop down list select the Perform Command, then click "Add".
- Rename the command
name to "Perform_01" by double on the "NewPerformCMD"
under command name.
- In here, you can use
the "Import iCommand" to import any of the commands you have
saved. You may also use "Export iCommand" to export
individual iCommand you wish to use in other Perform Command list.
The "Delete All" button clears all the command that are under
the command list.
