Create New Commands:
Operate Commands
Operate commands allow the
character to interact with the prop, then this turn the prop into an
interactive prop.
- From the command
drop down list select the Operate Command, then click "Add".
- Rename the command
name to "Operate_01" by double on the "NewOperateCMD"
under command name.
- In here, you can use
the "Import iCommand" to import any of the commands you have
saved. You may also use "Export iCommand" to export
individual iCommand you wish to use in other Operate Command list.
The "Delete All" button clears all the command that are under
the command list.
