Command/ClipSeq Interface You can add multiple commands in the Command Section, first select the command type from the drop-down list, then press the Add button to add commands. Double click to rename the target command name, press delete button to delete command, or export command as a library for future reuse.
Once you've added a new command, you can assign the corresponding animations to the selected command through the ClipSeq interface. You can define the playback sequence of several animation clips, or determine the loop time and trigger relation between them.
Note: Press the "Delete" key on the keyboard to delete individual command or clip. |
