ClipSeq Section
ClipSeq allows you to apply
motions to your selected command. When you have multiple motion clip you
will need to use the trigger clip at the very right column.
- Choose one of the clip types and click "Add Clip".
- The clip is now added
into the clip list.
Noticed when you add an AnimationClip, the application asks you
to import a motion file. Browse to the motion folder under iClone3 directory or the motion file you have created yourself.
iClone3 Motion Folder Directory |
Character Motion |
C:\Program
Files\Reallusion\iClone 3\Template\iClone Template\Motion |
| Prop
Motion |
C:\Program
Files\Reallusion\iClone 3\Template\iClone Template\iAnimation |
Trigger Clip allows you to set which clip to play after one
another. For example, if I want to have the "Visible"
clip played after the "Particle" clip. Then, I will place "1"
in the trigger clip column for the "Visible" clip.
Where does that "1" come from? It's from the "No."
column of the Particle clip. When this is set, visible
clip will be played after the particle clip is done.
In the
ClipSeq section, you can copy and paste the clip to another new
command's ClipSeq section.
You can
set the "Delay" time and the "Loop" time for each
individual clip.
When you
want to delete each clip, have the clip selected and press the
delete key on the keyboard. When you want to delete all the clips in
the list, you can simply press the "Delete All" button.
