Actor Root vs. Motion Root The actor's root and the motion's root are the two knowledge bases you need to know before you start using AML ScriptEditor. Let's
image that when you have a doll inside a display box. In this case, the
box would be the actor root and the doll is the motion root.
The following are demos when each of the root is been dragged.
Note: When you have applied first animation clip to a character. Afterwards you want to apply second animation clip to the character. If you did not sample the motion root to the character, then when you apply the second animation clip to the character the motion root will be dragged to the original start point when the first animation clip starts its motion. Please refer to iClone3 Online Help for more information about Actor Root and Motion Root. |
