Main Menu |
Open |
Ctrl + O |
Export to iClone |
Ctrl + E |
Export OBJ |
Ctrl + B |
Export FBX |
Ctrl + X |
Export BVH |
Ctrl + V |
Reload |
F5 |
Refresh |
F6 |
Undo |
Ctrl + Z |
Redo |
Ctrl + Y |
Toggling to Object-Manipulating Tools |
Select Object |
Q |
Move Object |
W |
Rotate Object |
E |
Scale Object |
R |
Preview Window and Camera Tools |
Quick Camera Positioning |
A - Left S - Right D - Back F - Front G - Top H - Bottom J - Face K - All Home - 45 Degrees |
Camera Manipulation - Zoom |
Z |
Camera Manipulation - Pan |
X |
Camera Manipulation - Rotate |
C |
Information |
Ctrl + F |
Pixel Shader |
Ctrl + F1 |
Tips - Speed movement: Holding the Shift/Control key will increase/decrease the movement (of camera and object) speed by 10x. |
Indicators (Show/Hide) |
World Axis |
Ctrl + A |
Grid |
Ctrl + G |
Dummy |
Ctrl + D |
Play Bar |
Play / Pause |
Space Bar |
Scrolling to Specific Sections in the Modify Panel |
Node Section |
I |
Transform Section |
T |
Pivot Section |
P |
Normal Section |
O |
Animation Section |
M |
Character Section |
N |
Replace Mesh Section |
V |
Head Morph Section |
B |
Material Section |
Y |
UV Settings Section |
U |
