Pipelines to Transmit Models
The pipeline for transmitting models is described in the illustrations below. You may also check out our web site for more details about the pipeline.
Maya, Max users
Please use the plug-in provided by Reallusion to convert the objects into VNS files and then apply them in iClone.
Other 3D Tools
Zbrush
Zbrush is a special application for generating normal maps of low polygon 3D objects. The normal map cannot be imported into 3DXchange. Therefore, the pipeline of it is a little different from other 3D tools.
