Click the Export (Ctrl + E) button in the Tool Bar.
In the Export iClone Content dialog box, key in the file name.
Refer to the Export Options section for more information about how to set these options.
In the Destination section, select the iClone Version to which you want to export the model via the iClone Version drop-down list.
You may also manually change the destination folders (described below) for storing the model or motions of the model.
Click OK button to export the model as a prop or as a character.
Select the iClone Content Folder radio button for Model and Motion (enabled only when you have generated motion clips) to convert the model into the default custom folder:
C:\Documents and Settings\All Users\Documents\Reallusion\Template\iClone 4 Template\iClone Template\
Choose the Custom Folder radio button and click the Browse... button to convert the model into your favorite folder.
Click the button to set the Custom Folder path to the iClone Content Folder, by
default, in:
You may then create new folders in it to build your own custom avatars or props library.
