Download
Buy
Upgrades
Quick Conversion
Easy interface to edit & prepare models for iClone
Drag & Drop Import
Simply drag-and-drop to import 3D models, directly from the iClone content gallery or Windows folder.
Supported file format:
Open format: 3DS, OBJ, SKP, FBX (PRO only)
iClone format: VNS, iAvatar, iProp, iAccessory
Quick Multiple Selection
Directly ctrl-click on target elements, or box select for multiple items. Super-fast selected items grouping, and further scene tree hierarchy management.
View the polygon count information for select items right on-top.
Shader & Lighting Option
Enhanced with Pixel Shader, the model looks exactly the same as you load it into iClone. Change Lighting Options to check the bump or normal map effects when making material adjustment.
All images are real-time rendered using iClone4
