Import and Convert 3D Files into iClone
New! Load and convert 3DS,
OBJ, SKP files into iClone VNS format.
New! Edit models between
3DXchange and SketchUp smoothly.
Build up a massive iClone model library from professional
3D models - scenes, props, and accessories.
Load iClone VNS files for material editing, pivot setting,
or edit iClone VNS Merged Props.
Full texture conversion keeping materials intact - unwrapped
UV, multi sub-material texturing, diffuse, bump, and opacity.
Texture format supported: JPG, BMP, PNG, TGA, TIFF.
Support 3DS animation data import and export (spline
not supported).
Selectable export for breaking up model groups: check
on/off mesh nodes in Scene Tree to filter output elements.
Transformation,
Material Editing and Attribute Setting
New! Material attribute editing
provides more material flexibility (Opacity and Self-illumination)
New! The enhancement of auto
smooth and weld vertex for SKP 3D objects.
Material Editing: material color, glossiness, specular
(how shiny the material appears, eg. plastic, metal, or
glass).
Normal Correction: 2-sided, flip, unify.
iClone Shadow Attribute Setting: Cast Shadow, Receive
Shadow.
Scene Transformation: Rotation, Translation, Scaling.
Quick Align to Scene Root: Auto-align scene elements to
iClone root ground position.
Edge Smoothness: define hard or soft edge by specified
angle threshold.
Pivot Setting: set pivot for rotation in iClone, eg. door
- rotate based on edge, wheels - rotate based on center.
Ease-of-use
Design
New! Add an Exporting Selected
node function to save selected items quickly.
New! Increase efficiency
by "Hide Excluded/Show all Items under scene Tree".
New! Display shader situation
and object face number in 3D windows.
New! "Drag & Drop"
file importing: 3DS, OBJ, SKP or VNS file formats.
Scene Tree: multiple elements selection for node attributes
editing.
Schematic view of individual model segments for simple or
complex models.
Quick project reload - press F5 to reload last project,
effective tuning loop for model creation.
Quickly export VNS files to iClone folders - scene, props,
accessories, user define.
Keep last file path assignment to save frequently used
folders.
Auto model scale up and display dummy figure for size
reference, when the original model unit setting is too small
to view in 3DXchange.
Free
3D Resource Collection
New! Free access to 3D models
from
Google 3D Warehouse directly.
Download models with 3DS, OBJ or SKP file format from
3D resources like Turbo Squid, Renderosity, and Amazing
3D, to generate massive 3D models for iClone accessories,
props, and scenes.
Download
Free 3D models
Linkage to Power Tools
Bring your custom designs from world famous 3D modeling
applications (ZBrush, Max, Maya, Google™ SketchUp,
etc.) to iClone and turbo charge models into real-time movie
production.
See pipelines from
3D applications to iClone
Application
Compatibility - Free Trial -
Examples
