Home
Products
Purchase
Downloads
Partner
About Us
Download
Buy
Upgrades
Application Export Data Compatiblity Table
(This table is based on the result in 3DXchange import and tested by Reallusion.)
Exporting Objects from 3D Application
Compatibility of Importing 3D Objects to 3DXchange
Application Name Supported File Formats
for 3DXchange
Export Options Animation Key Pivot Mesh Normal/
Smooth Group
Material Color
Specular/
Glosiness
Texture UV Diffuse Map Opacity Map Bump Map Reflection
Map
iClone 2
VNS
Yes
Yes
Yes
Yes
Yes
Yes
Yes
Yes
Yes
Yes
Yes
SketchUp6New!
SKP
Yes
N/A
N/A
Yes
N/A
Yes
N/A
Yes
Yes
Yes
N/A
N/A
SketchUp 6 Pro
3DS
Yes
N/A
N/A
Yes
Yes
Yes
N/A
2 Yes
N/A
N/A
N/A
OBJ
Yes
N/A
N/A
Yes
Yes
Yes
N/A
1 Yes
2 Yes
N/A
N/A
N/A
Wings3D 0.98
3DS
Yes
N/A
N/A
Yes
Yes
Yes
N/A
Yes
Yes
N/A
N/A
N/A
OBJ
Yes
N/A
N/A
Yes
Yes
Yes
N/A
Yes
Yes
N/A
N/A
N/A
Zbrush 2
3DS
OBJ
N/A
N/A
N/A
Yes
N/A
N/A
N/A
Yes
Yes
N/A
Normal map
N/A
DAZ Studio 1.5
3DS
OBJ
Yes
N/A
N/A
Yes
N/A
Yes
Glossiness
only
Yes
Yes
Yes
Yes
Yes
Bryce 6
3DS
OBJ
Yes
N/A
N/A
Yes
N/A
Yes
N/A
Yes
Yes
Yes
Yes
Yes
Poser 7
3DS
OBJ
Yes
N/A
N/A
Yes
1 Yes
Yes
Glossiness
only
Yes
Yes
N/A
Yes
N/A
Vue 5
3DS
Yes
Yes
Yes
Yes
Yes
Yes
Yes
Yes
Yes
Yes
Yes
N/A
OBJ
Yes
N/A
N/A
Yes
N/A
Yes
Glossiness
only
Yes
Yes
N/A
Yes
N/A
Shade 7 E Professional
3DS
N/A
N/A
N/A
Yes
Yes
N/A
Yes
N/A
N/A
N/A
OBJ
Yes
N/A
N/A
Yes
Yes
N/A
Yes
Yes
N/A
Yes but wrong
LightWave 3D 9 Modeler
3DS
Yes
N/A
Yes
Yes
N/A
Yes
1 Yes
3 Yes
3 Yes
3 Yes
N/A
OBJ
CINEMA 4D R10
3DS
N/A
N/A
Yes
Yes
Yes
Yes
Yes
Yes
N/A
N/A
N/A
N/A
OBJ
N/A
N/A
N/A
Yes
N/A
N/A
N/A
Yes
N/A
N/A
N/A
N/A
N/A: the original software is not supporting this feature for export
Notes:
iClone 2
  1. Motion clips can be obtained if not checking "Centralize pivots to individual mesh nodes" in the exporting procedure of 3DXchange.
SketchUp 6 Pro
  1. Also support mutiple textures.
  2. Use PNG format for both Diffuse and Opacity map.
Bryce 6
  1. Maps need to be ressigned in iClone
Poser 7
  1. Poser model has smooth group.
  1. The normal of some faces mab be flipped. This flipped normal can be fixed in 3DXchange.
  1. The value of Glossiness is for both Specular level & Glossiness.
  2. The UV of exported 3ds model is not correct and should be mapped the UV again if you want to assign the texture maps on this model.
  3. Only the file paths of maps are specify. Users have to find the maps by the paths information and assign them to the model in iClone.
