Home
Products
Purchase
Downloads
Partner
About Us
Download
Buy
Upgrades
Faster & Smarter Manipulation
  • Drag and drop editing from files on your computer or external hard drive.
  • Directly turn image or video files into 3D objects.
  • Gizmo manipulation with 3D Viewer.
  • Ability to direct your actor or prop with accessory hot key menu in the Director Mode.
  • Dockable and collapsible Timeline Editor.
popVideo & 3D Video FX
  • Supports video files (AVI, WMV,MOV, FLV, etc.) in any texture channel.
  • Video layering for foreground, background, titling and SFX.
  • Turn video with alpha channel into popVideo for iClone.
  • Place video on any surface of 3D objects for 3D video SFX.
Visual Enhancement
  • HDR (High Dynamic Range) effects.
  • IBL (Image Based Lighting) effects.
  • Enhanced shadow map for flexible shading effects.
  • Particle softness and orientation for realistic SFX.
  • Realistic water animation with video normal map.
  • Smooth blending between water and land with edge softness.
  • Rotation-driven spring animation for naturally moving hair and skirts.
Smoother Animation
  • Motion Path with speed, orientation and editing control.
  • Transition curve for more natural object movement.
  • Smoother camera motion for better camera movement.
  • Full hand gestures with fast motion editing.
  • Motion reverse.
Built-in Facial Editor
  • Facial puppeteering – Use your mouse to select and direct the facial features of your actor as you play back in real-time.
  • Enhanced G4 head system with facial bone level morphing and key editing.
  • Enhanced facial tracks in Timeline for keyframe or motion clip management.
Texture Share & Blending
  • Decrease file size by using external textures and sharing textures for multiple objects.
  • Eyedropper and paint bucket for quick texture editing.
  • Adjust UV map with rotate, mirror, and invert.
  • Blend textures with different modes: multiply, addition, overlay.
New Characters and Content Goodies
G3 Human Character
- Dylan & Jane
G3 Cartoon Character
- Jimmy-Toon
G4 Head with Normal Map
- Benny
Non-human Character
- Lamp (PRO only)
  • New characters with G4 head system optimized for advanced facial animation.
  • Character base for stylized cartoon animation - Jimmy-Toon.
  • New persona motion files for daily movements and dialog.
  • Be able to import facial texture files from Poser and Second Life.
  • Add new behaviors to avatar by attaching new props: wings to add fly mode, glove to add boxing mode.
  • Be able to edit and animate 3D creatures other than human.
Other Enhancement
  • Added: Allow set pivot for any object to create rolling wheels, doors and other smart props.
  • Added: Decimal precision to the transformation of props.
  • Added: Dummy mode - set prop or accessory as dummy for easier manipulation.
  • Added: Create head with bone level morphing.
  • Added: AML human centric - actor is able to perform specific motions by accessing different AML accessories.
  • Added: Enhanced Scene Manager with freeze function.
  • Added: Individual sound track for characters, props, etc.
  • Added: Detailed hand management, with ability to save gesture clips.
  • Added: Accept UV face map from 3rd-party model in enhanced G4 head bone system.
  • Added: New type of "Gloves" for character style setting.
  • Added: Eyelashes available in new G4 head.
  • Enhanced: Able to see trees or grass in Quick Shader.
  • Enhanced: Preference panel update.
  • Enhanced: Quick Access function for Modify panel.
  • Enhanced: Highlighted texts in Modify panel allow key animation setting.
  • Enhanced: Quick switch between Director and Editor mode
  • Enhanced: Ability to customize file thumbnail.
  • Enhanced: Right-click menu with scroll bar for flexible search.
  • Enhanced: Collapsible Timeline editor with track grouping and show/hide function.
  • Enhanced: Ability to do key animation of image layer and multiple layering.
  • Enhanced: Atmosphere and sky tracks enhancement.
  • Enhanced: Flexibility to adjust shadow quality by adjusting map resolution range.
