Check the system requirements first to see if your computer has the system requirements needed to install.
Check out the feature matrix to see the difference between EX, Standard, and PRO version.
Installation Instructions:
Follow
these instructions to install iClone3 EX edition:
Locate and run "iclone.exe". Click
OK to start the InstallShield Wizard.
After the files have been extracted
you will see the "Welcome to iClone Setup" screen. Click Next
to begin installing the iClone3 EX program.
Read the License Agreement and
click Yes only if you accept the terms.
Click Next to use the default
destination folder or click Browse to select a different folder
and then click Next.
Click Next to select the default
program folder; alternatively, you can type in the name of a
different folder or select one from the Existing Folders list.
Then click Next. Setup will copy files to the disk.
Setup will complete copying program
files to your system and updating the register. You will see
the "Setup Complete" screen. Click Finish to complete the
installation.
After
installation, you can get FREE bonus content for EX edition. Simply
follow the instructions to download the free bonus.
System Requirements:
Hardware
Pentium4 2GHz or higher recommended
1GB RAM or higher recommended
2GB hard disk or higher recommended
Display Resolution: 1024 x 768 or higher
Color Depth: High Color (24-bit) or True Color (32-bit)
Graphic Card*: Support for DirectX 9.0c and Shader Model 3.0
Video Memory: 256MB RAM or higher recommended
Sound card / Keyboard / Mouse / Speaker
Video card compatible with Pixel Shader 3.0 recommended for
optimized visual performance
3-button mouse
Recommanded Hardware (iClone will have better performance
in below recommanded environment.)
Dual core CPU or higher
Graphic Card: Nvidia GeForce8 Series or higher/ATI HD 2400 or
higher
Operating System
Windows XP SP2 / Vista
Internet connection required
for online activation.
DirectX 9 and WMEncoder
9 are required for WMV exporting.
Graphics Card Support List
Graphics
Card
Quick
Shader
Vertex
Shader
Pixel
Shader
nVIDIA
GeForceFx 5200
GeForce6 Series
GeForce7 Series
GeForce8 Series
ATI
8500
X1xxx Series
HD2xxx Series
HD3xxx Series
Intel
GMA 950 (Intel 945G)
GMA 3000 (Intel G965)
GMA 3500 (Intel G35)
* If your Intel Graphics Card has any display issues, please update your Graphics Card Driver.
