Creating Custom Web Avatar File
CrazyTalk provides the Widget export feature to generate your customized interactive Web Avatar. By using different default Web Avatar projects, you may easily create a web avatar with or without a backboard. The exported Web Avatar can then be embedded into your web page or blog to attract the audience.
Creating Web Avatar with/without a Backboard
  1. In the Project page:
  2. Optionally modify the avatar.
  3. Adjust the talking script of the avatar.
    Please note while in the Stage panel:
  4. When you are prompted to view the result, click Yes if you want to see it in your browser.
    Note:
    • Search the 'bgcolor','#ffffff', in the source code of the exported SyncVideo.html and change it to 'bgcolor','#000000', to see the difference between the web avatars with and without backboard on the web page.
      With Backboard
      Without Backboard
Loading Web Avatar into External Widget Editor
If you have a Widget Editor installed on your system, you may then use the exported interactive web avatar as a widget in the widget project.
  1. Launch the widget editor and create a new widget project.
  2. Click the Insert Flash (SWF) button.
  3. Select the SyncVideo.swf file in the same directory where you saved the web avatar.
    You may then see the difference between the web avatars with and without backboard when they cover other widget objects.
