In CrazyTalk, you may change the speed and loop status of clips in the Motion Clip track of the timeline. Adjusting the length of the speed, loop and blending is also possible.
| Speed | ||||||
| Loop | ||||||
| Blending | ||||||
By default, motion clips will blend with the auto motion,
which make the transition between two motion clips smoother. If you wish to manually blend two motion clips together, then follow the steps below:
