The Auto Motion track stores one audio driven motion for the entire project.
Depending on whether the audio data is loaded or not, there can be two types in the track -
Auto Motion and Idle Motion.
Auto Motion
When audio data is given, the auto motion can be produced under the following situations:
When loading an audio data
and selecting Talk Mode as the default auto motion,
the motion pattern will be automatically applied to the actor.
and selecting Listen Mode as the default auto motion,
Switch the Content Manager to the Auto Motion tab,
and apply a template from the Functional or Scenario library.
Note:
If you apply a designed projects or talking scripts sample,
then there will be data stored in the Auto Motion track as well.
Idle Motion
If audio data is not available, then the idle motion can be produced under the following situations:
When an actor is created without voice scripts,
then the default idle motion will be automatically applied to the actor.
and selecting Lips Sync Only as the default auto motion,
and apply an idle template from the Idle library.
