Applying and Creating Motion Clips
After an Auto Motion is applied to the actor,
users can then overlap the actor's motion with ready or custom motion clips
which are stored in clip form inside the Motion Clip track.
Applying Motion Clips
When you apply a motion clip template,
the data will be stored in the Motion Clip track.
If you wish to create a custom motion clip from the current project,
then the data saved in the custom library may vary depending on the following situations:
- Selecting single-motion clip:
Data in the Motion Clip track will be saved alone.
Clip 01 will be saved alone.
- Selecting multiple motion clips or not selecting any motion clip:
Data in the Motion Clip and Auto Motion
tracks will be merged before being saved.
Clip 01, 02, 03 as well as the Auto Motion will be merged before being saved.
Note:
The data structure of a created custom script is a bit different.
You may refer to the
Using Talking Scripts
section for more details.
