Adding or Modifying Lip-sync Keys
CrazyTalk provides special lip synchronization tools to make sure that
the lip movements match the words being spoken by the virtual actor.
A viseme is a generic facial image that can be used to describe a particular sound.
It is the visual equivalent of a phoneme, or a unit of sound in a spoken language.
Using visemes, CrazyTalk provides perfect lip synchronization which
you can later adjust for different sounds as required.
The lip-synching keys are stored in the Lips track,
which belongs to the Audio track.
You may open it by clicking the
button on the Audio track.
Audio Track and Lips Track
The Audio track stores the audio file from the
Import Audio panel
or the Voice Script Library.
The audio data is displayed in a wave form.
You may double-click anywhere on the track to load an audio file.
Click the button on the
Audio track to show the Lips track.
You may manually add lip-synching keys to this track by double-clicking on the cells in this track.
The lip synchronization effect is applied to only a small section of the script and
indicated on the Lips track by a grey box.
To access the Lips Sync panel,
click the Lips Sync
button in the Timeline.
Adding Lip-sync Keys
Lips track to synchronize the lip movements in the Lips Sync panel.
Select a viseme or phonetic sound from the various options displayed.
Move the Expressiveness slider to adjust the strength of the lip movements to specify the intensity.
"Ah" sound applied
Expressiveness = 50
"Ah" sound applied
Expressiveness = 100
You may move the lip-synching keys to other parts of the script as desired, or use the data editing tools
to duplicate the lip movements.
To modify a lip-synching key, double-click on the target key to adjust the lip-synching settings in the Lips Sync panel.
