Add a Background Image
Since the unwanted, original background of the image is masked from view,
then you can now change the background image or color at ease.
Apply Background from Library
Switch the Content Manager to the Background tab,
and drag and drop a template from the library to test the applied results.
Use a Custom Background
You may choose to use the original or another image as the background.
Let us change the background color for the actor.
Click the Background Setting
button on the tool bar.
The Background Setting panel will then open.
Select Actor Only.
Click on the color box next to the Color Selected option,
and choose a desired color in the Select Color panel.
The background color will then be changed.
Note:
The Select Color panel provides many kinds of color selecting methods.
You may utilize the RGB sliders in the Color Sliders tab
to create a blue or green screen for creating your own photo montages.
Set RGB = (0,0,255) for a blue screen
Set RGB = (0,255,0) for a green screen
