Start a Project
All templates in the Project tab are ready for your use.
You may direct drag and drop any one of them to the working area and view the project result right away.
Apply Project from Library
Let us start with some sample projects that are built into CrazyTalk.
Switch the Content Manager to the Project tab.
Drag and drop a desired template from the library. The actor will then start to talk, or listen with or without motions.
Create a New Project
To start a CrazyTalk project from scratch,
click File >> New Project (⌘ + N) from the Main Menu.
Then you will have a clean working area with a white background.
