Auto Motions are motion patterns that are automatically generated when an actor
is applied with a voice in Talk or Listen mode.
When the actor is in the Talk mode,
the actor's motion will be more active especially when it touches the peaks of the voice wave line.
On the contrary, the actor listens and passively reacts to the context of
the voice when it is in Listen mode.
Generating Auto Motion
Create a new actor or apply an actor from the library.
Click the Import Audio button on the tool bar.
You may choose either way to
generate voice for the actor.
Once the voice is generated, you need to determine the mode for applying the voice.
Talk Mode: The actor talks with
spontaneous motions in accordance to the context of the voice.
Listen Mode: The actor listens to the voice with motions
reacting to the voice.
LipsSync only: The actor utters with
only mouth shapes and idle motions.
Playback the project. The actor starts to talk or listen to the voice with motions.
Note:
Please note that at the end of the steps, the actor's motion is in default motion
patterns. By
applying different auto motion templates, the actor moves with
different motion patterns.
If the actor has been applied with auto motions, then you may
further adjust
to ease or dramatize the motions.
