Adding Voice to an Actor
An actor in CrazyTalk can open its mouth and speak. You may use four methods to add voices to an actor.
  1. Click the Import Audio button on the top tool bar. Inside the panel you will find four different methods for importing voices.
  2. Choose a method and click its button.
Note:
After the voice is generated, you will then be asked to determine the loading mode in order to generate an Idle Motion or an Auto Motion for the actor.
