Setting Default Project
After creating a project you may have a need to repeatedly open it, especially if you are sharing with others in a work group. To do this, you may save the project as a default project and instantly load it each time you launch CrazyTalk.
  1. Switch to the Project tab on the Content Manager.
  2. Save your current project into the Custom library by clicking the Add button.
  3. Right-click on the newly-added template icon. A menu will pop up.
  4. Select Set Default Project.
  5. Restart CrazyTalk. The new project has now replaced the initial default project (white background).
    Note:
    • All the settings of the project will become the default project settings.
