Once a project is created, you may save it at any time.
Switch the Content Manager to the Project tab
to save the current project as a new project,
or to overwrite an existing project.
Save as a New Project
Click the Add | Save
button.
A thumbnail icon will then be created in the Custom tab.
Specify a name to the project.
You may also click
File >> Save As Project
(Shortcut: Windows - Ctrl + Shift + S; Mac - Shift + ⌘ + S)
from the Main Menu.
Overwrite an Existing Project
Highlight an existing project in the Custom library,
and then click the Add | Save
button.
The old project will then be replaced.
Note:
Every project saved in the Content Manager can be set as the default project.
Right-click on the project icon, and select Set Default Project.
Then you may instantly load it each time you launch CrazyTalk.
