Optionally, you may choose to load audio files or use a TTS engine to create custom voices.
Let's record an audio segment for the example.
Creating an Audio Clip
Click the Import Audio
button on the tool bar.
The Audio Import Options panel will then open.
Click the Record Audio button.
Start recording your voice by clicking the Record button.
Click the Stop button to stop; Play button to play back.
The maximum length of a sound recording is 15 minutes.
Note:
To properly record the audio, make sure the voice waves are averagely presented.
Not recommended
Recommended
Not recommended
To get rid of sound breaks, switch your MAC OS to
System Preferences >> Sound >> Input tab,
and make sure the Input Volume slider is not dragged to the extreme right.
Click the OK button when done, and select the Listen Mode.
The actor will then start to listen to your own voice and animate according to the default auto motion.
Use the left-side tool bar to move (Shortcut: M), rotate (Shortcut: R), or scale (Shortcut: S) to best observe your actor
and back to the original position (Shortcut: Home).
If the default auto motion is not so suitable for the actor, then you may
change the auto motion to a better one.
