Once returned to the working area with the actor,
you may proceed to edit the background mask before a custom background image can be properly used.
Auto Mode
Click the Mask Editing
button on the tool bar to access the Mask Editor Panel.
By default, CrazyTalk has automatically estimated the most necessary parts for us in
Auto Mode.
Press down the Actor Brush
button and roughly draw contours to frame around the actor.
CrazyTalk will estimate the actor's edge according to the contours.
Using Actor Brush
Actor contour created
Click the Preview button and use the Zoom In
(Shortcut: + or Shift + "=")
button to enlarge the image and check the mask result on the edges.
If the result is not very well,
click the Go to Manual Mode button to deal with the details.
Manual Mode
In Manual Mode, press down the Eraser
button,
then drag the Brush Size slider to the left (Shortcut: [),
to decrease the eraser size and refine the edges.
Click the Preview button to check the results again.
If you find jagged edges,
use the Zoom In
button to enlarge the jagged area.
Then press down the Blur
button and paint on the edges of the mask to smooth the edges out.
Jaggy edges
Jaggy edges removed
Note:
Alternatively, use an external image editor (e.g. Photoshop) to predefine the alpha channel for mask editing
before loading your image into CrazyTalk.
The alpha channel can be in 32-bit BMP, TGA or PNG format.
Click the OK button when done and back to the working area.
Then you can add a background image to the actor.
