Since the unwanted, original background of the image is masked from view, then you can change the background image or color at ease. |
| Applying Background Images from Library | ||||||
Switch the Content Manager to the Background tab,
then drag and drop a template from the library to test the applied results. |
| Using a Custom Background Image | ||||||
You may choose to use the original or another image as the background. Let's change the background color for the actor.
