Play Bar
The Play Bar is used to control scene playback in CrazyTalk.
Play Head
Shows the current frame of the project. You may quickly drag it into any desired frame.
Voice Volume
To adjust the volume of the sound effect.
3
Previous Frame
To jump one frame backwards.
4
Jump to Start Frame
To jump to the cue frame of playback, or to the start frame of the project.
5
Play (Shortcut: Space bar)
To playback the current project.
6
Stop
To stop playback.
7
Jump to End Frame
To jump to the cue-out frame of the playback, or to the end frame of the project.
8
Next Frame
To jump one frame forwards.
9
Loop On/Off
To toggle playback loop on/off.
10
Current Time
To show the current time/frame.
You may click the Time Unit button to toggle between time display modes.
  • - Time Mode: Display time in mm:ss:ms format.
  • - Frame Mode: Display frames. The unit is 30 frames/sec.
11
Show Timeline
Bring up the Timeline.
12
Music Volume
To adjust the volume of the background music.
13
Playback / Export Range
Drag the red triangles to determine the playback / export range.
