CrazyTalk offers you to output Sequence BMP or Sequence TGA image files. Please follow the steps below.
Click Image tab to toggle the
output mode.
Select the format in the Format drop down list.
Modify the Output Settings.
Click Export .
You may output sequence image files in YouTube format:
Select the Sequence BMP or Sequence TGA item in the Format drop down list.
Click the Target Resolution radio button, select YouTube in the drop down list.
Adjust the other output settings. Click Export
Note:
